Stupid question # 2 ( today). How can you tell a B6 sohc from a B3 by looking at its exterior?
B6 vs B3
Water inlet (where the bottom rad hose connects to water pump) is not long and curvy like on a B3. The exhaust mani is longer than on a B3. If its a '90+ B6 then the valve cover is much more rounded than a B3. If its a pre '90 B6 then the dizzy will look like a carbie B3 dizzy, with vac lines going to it. Also, somewhere on the head should be cast B61K (I think) and on the B3 I believe it says B301? Those are the ones off the top of my head, I'm sure there are more, its been a long day at work lol, still 5 more hours of my other job to go.No festiva for me ATM...
valve cover should be easiest93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
RJ
There is a heavy "ear" sticking out as part of the block right in the area where the distributor, starter, and bell housing come together on the firewall side that is machined smooth on top and stamped with either B3 or B6. Depending on the amount of rust on the block it may be hard to read.You gonna race that thing?
valve cover is the same on 88-89. 2nd gen is different, yeah?
The B6 will have "61K" embossed on the head just below the valve cover, between the two center sparkle plugs. At least my gen 2 B6 does.Originally posted by navdoc101 View PostStupid question # 2 ( today). How can you tell a B6 sohc from a B3 by looking at its exterior?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
^ Thats cool you said SPARKLE plugs.Mind if I recycle that one?Some people like to read fiction,I prefer to read repair manuals. Weird I know-
haha ^^ mercury tracer or mazda 323
Not original I'm afraidOriginally posted by nitrofarm View Post^ Thats cool you said SPARKLE plugs.Mind if I recycle that one?
. See below:
