Stratified Megasquirt PNP for 1995 Aspire B3+T
  • #16
    Originally posted by Flyin4stroke View Post
    what are you guys using for tps? or are you running completely on map sensor? My tps wires aren't hot, no voltage so i was wondering what i could do to get it to work? i swapped the tps to a vtps cause i know its better but i heard i need to run a extra wire to the distributor?
    Run a Hyundai TPS
    • #17
      Checked my narrowband output today as per the WSM and it works fine. warmed up the car, ran it at 2500 rpm for 3 mins. Shut it off, connected my dvom to the sensor output and ran it. It was sitting at .6v then I pulled a vacuum hose and it went to .1 then I allowed it to stabilize and pulled a plug wire and it went to .9v. I wanted to check the output to the PCM tonight and proceed with the tuning but unfortunately I punctured my hand at work right at the end of the day and now am waiting for a couple of stitches. Atleast our dealership has a running tab with the hospital down the street. Lol Jk..
      Tim
      '97 Aspire ST, UltraViolet Blue, 37k miles - New Storage Queen
      '03 SVT Lightning, Dark Shadow Gray, 30k miles - Storage Queen 11 months/year
      '95 SVT Aspire B3T, Green Mica, 75k miles - DD
      '01 ZX-500R, Violet Pearl/Gray, 5400 miles - Storage Queen
      '89 Suzuki FA50 Bright Red - Lake Transportation
      Cardomain.com/id/aspiresvt
      Previous Vehicles
      '92 Festiva L "Sport" Green Mica
      '92 Festiva GL Blue Pearl
      '92 Capri XR2 Performance Red
      • #18
        a) im sure your body doesn't appreciate that
        and
        b) Are you running a wideband? i know i hooked up my MSPNP with my AEM uego via the narrow band wire on the harness and played around with the narrow band settings/voltage value.
        • #19
          Originally posted by festyfreak39 View Post
          Run a Hyundai TPS
          But that doesn't help me with getting power to my tps wires.
          1989 Ford Mustang GT 5.slow
          1996 Ford F-150
          • #20
            SVT, since you are also playing with engine control maybe you know the answers to my noob questions? There are in my thread http://www.fordfestiva.com/forums/sh...l=1#post565465
            rusEfi - DIY ECU
            93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
            • #21
              Yes I do have a wideband, innovate motorsports. I kept with the oem hookup for now just to get it going. The wideband is more a less a monitor at the moment but it will be used in the future as an input to the mspnp
              Tim
              Previous Vehicles
              • #22
                Bumping my thread. My Aspire is now running on the MSII. Fords resistance values charts for the temp sensors were wrong much like the evtm. I didn't assume they were correct but I tried them anyways. ended up measuring various values from 7 degrees up until 190 for the ect and 10 degrees up to 150 for the iat so I had a nice chart to pick from. It's far from tuned perfectly but I am very happy so far. It's a great learning tool.
                Tim
                Previous Vehicles
                • #23
                  Hi 'ya Tim,
                  On My megasquirt install I measured the sensors as well and discovered the values were different then the published data. Congratulations on getting the Aspire running!
                  How's is your cold starts?
                  Jim
                  • #24
                    Cold starts are crappy, even warmer engine starts are lean for some reason. I have to tip in the throttle for about a minute or so then it will hover around 14-15 afr. I also have a stumble at around 1100 rpm when I let the clutch out. It's almost like its a fuel cut. If I tip in slightly higher and don't let it drop to 1100 as I let out the clutch it's fine. I also coasted down in 2nd gear and right around 1100 again it did the cut. It idles fine. So it's far from perfect but I will continue to research and adjust
                    Tim
                    Previous Vehicles
                    • #25
                      I upped the ase percentage and adjusted the taper, cold starting is a bit better, still going to tweak that. Found my tip in accel problem, apparently there was a 0 in one of my spots on the ve fuel table. yReplaced it with a value closer to the ones around it and my fuel cut is gone, who'd a thought.. The tweaking continues, 2nd-4th gears are becoming way funner so far.
                      Tim
                      Previous Vehicles
