I've looked in the haynes and chiltons manuals, 2 different forum write ups for tearing down a G series tranny, and a couple other things for the torque specs, but I'm not seeing the torque specs for the casing bolts. Anybody know what these need to be tightened to? ...and should I use loctite or the ARP thread stuff or just torque them dry?
G series case torque spec
2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
"If it moves, grease it, if it don't, paint it, and if it ain't broke don't fix it!" -
Bump2008 Kia Rio- new beater
From ALLDATA site
TY sir, its a cable clutch transmission, but the numbers I'm after is the transaxel case-to-clutch housing 18-24nm or 13-18 ft lb right?
Thanks man..2008 Kia Rio- new beater
That's why I posted, I was torkin down the case bolts on my Rio transmission and I did 25, then jumped to 40 and snapped the head off a bolt. Didn't want to make the same mistake again with a transmission I'm going to use..id really like to do this right..2008 Kia Rio- new beater
The G25M-R Manual calls out 28-38 ft lb for the torque you requested.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
^ yea I just came across the FSM for it.. maxtiva was right if this was an F series transmission.
This site has a few different FSM pdf's
