So far I've lived with my B6 ATX swap now for several months.  I'm using an Odyssey PC 680 dry cell that is rated at 680 PHCA and 220 CCA.
It's worked fine until recently. It seems to be a bit weak now.
I'm using a 6 ga. battery cable for both pos and neg (ground). Since my battery is mounted in the back, maybe that's a long ways for the charge to travel. The wire may be too thin as well. "Electrical engineering" isn't my area.
I got this idea from a Honda guy who wrote up his Odyssey swap into a CRX with a 5 speed. My ATX is undoubtedly taking more juice to start due to the heavier ATX parts rotation, compared with an MTX.
I'm considering swapping to an Odyssey PC 925:
Before I do so, I'll switch to a heavier battery cable. Wil used an 8 ga. in his MTX writeup, so I figured 6 ga. would be good for me. Maybe I really need a 4 ga. I'll try that first.
If I get another battery, my current PC680 will go into Twinstiva.
Another thing I read concerned insufficient recharging of Odyssey batteries when used in Harleys. Short trips won't recharge the battery enough and it will slowly lose its charge. Could be happening to me too. Here is a link to Odyssey's new charger that also explains the story:
My guess is that the combination of my thin battery cables coupled with my relatively heavy ATX starting needs is wearing my poor PC680 down.
Any advice for me on this issue?
Karl
Karl
