I'm having trouble sourcing the gasket that goes between the oil cooler and the block, and the washers for the oil squirters. Also looking for the xr2 shaft locknuts. Azone, advance, and even my local place that has everything, can't even find part #'s for this stuff. It's not in their systems.
I compared the oil squirter washers to brake line washers and the outside diameter of the brake washers is a couple thousandths smaller..I don't know if they would expand that much when squished and I should just use those or what.
