Howdy all. I had thought of an idea & wanted to run in past everyone to see if there is interest.
Thought about making a heavy duty 5th gear cover for the G-series transmission. They would be cast alloy aluminum - 1/4" thick in most places, with a heavy duty mating flange & strengthening ribs that will double as cooling fins. Should look pretty cool once done, too, as well as offer way more support than the flimsy stamped cover.
This is the cover in question:
This should work on most/all FWD G-series transmissions including the V6.
I think the 4wd cover is different, I could easily whip up a version for the 4wd g-series too
Could also make one for the F-series if someone is willing to provide a cover for me to use a pattern/template.
Roughly estimated price is $100-150 per piece. What do you guys think?
