BP deck
BP deck
2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
"If it moves, grease it, if it don't, paint it, and if it ain't broke don't fix it!"Tags: None
lol, not trying to be a smart ass, but that is after scotch bright pads! and pb blaster, and over an hour of scrubbing.. I'm thinking I'll hit it with 1500 grit sandpaper in a few minutes and go find my ARP Head Studs..2008 Kia Rio- new beater
I was thinking about resurfacing it, and if it was a general concenses I would have, but from what I can gather it's about good enough. I really didn't want to anyway, the pistons are about ready to pop into the combustion chamber and I shaved .02" off the head, so that leaves very little room for error lol..2008 Kia Rio- new beater
If your using a cometic, they offer different thickness to compensate for haveing the head milled and the block decked. If you can snag you finger nail in any of those pits, just have it surfaced. It cant be that much.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
^ I considered cometic, but I'm going for that whole low rpm torque curve dare-to-detonate situation lol.. no really tho I already bought the felpro, so I'm using it.. if I was using a stock ecu and had to booger it to make the car run, I'd want lower compression ratio, but since I'm trying to use MS I should be able to tune it up right with a higher CR.
Cometic=.040 compressed, felpro/stock=.036 IIRC
I just tried the fingernail trick and couldn't get it to snag, even used my pinky..the thinnest/sharpest nail.. so I guess it's about that time..Last edited by zoom zoom; 05-01-2012, 08:49 PM.2008 Kia Rio- new beater
I'd still flat stone it like suggested.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
I made a simple resurfacing tool with a cheapo 1/3 sheet finishing sander and a piece of plexi shimmed "true" glued to the pad holder.
Worked fine, and much easier than hand sanding it.Any difference that makes no difference is no difference.
I just used a cutting board (new) with a piece of 1500 grit sandpaper on it, and used pb blaster to wetsand it, it's pretty shiny. Then I used fantastik (because i'm out of 409 atm) to clean the surface, it's pretty dry, I scrubbed it with a couple towells until it isn't slick anymore.
I installed the ARP head studs, "finger tight," then I twisted them an extra 1/8-1/4 turn to sink them into the block. The directions said "finger tight" but I read in a few books that sinking the studs into the block gives more clamping force on a head....anyway, I've got another problem, the 2 front studs don't twist as far into the block. The 2 on the timing belt side.. every other bolt goes in so far, then those outter 2 won't go any deeper. I don't recall any of the head bolts I took out being different sizes, and I know all the ARP studs were the same size. Anyone else had this problem? I ran a tap back down thru the holes and didn't get anything out, and I can't see anything with a flashlight down in the holes.2008 Kia Rio- new beater
use copper spray.... that will fill in those imperfections.Trees aren't kind to me...
You never mentioned straight edge but going from stud hole to stud hole
should show if you will have enough clamping force in that low area that
shows some pitting.
The short stud holes should leave a mark on the stud indicating end of threads
or bottoming on a casting flash.Reflex paint by Langeman...Lifted...Tow Rig
