I noticed the fan on my radiator still has a lot of radiator "area" around it being set up as a puller fan. There is very little room inside the engine compartment to really mount a larger fan. However, the outer part of the radiator has tons of space to mount a much larger fan as a pusher fan. Would the larger pusher fan be more efficient at cooling than the smaller puller fan?
Is a pusher fan or puller fan more efficient at cooling?
The same fan will lose 15 to 20 percent moving from a puller to a pusher.
If the pusher will move that much more air (CFM) it could be better.
If you can design the shroud to move air through every part of the raditaor that helps a bunch. There is a lot of capacity there if you are experiencing heating issues it could there could be other problemsReflex paint by Langeman...Lifted...Tow Rig
It's doing okay right now, but NC summers get really hot so I thought I'd upgrade to a larger fan. Fastiva has a 12 second car so if his 14 inch pusher is doing great, I might just do this simple upgrade.Semper Fi til I die!
1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
