My spiffed up B3 Valve Cover.
  • My spiffed up B3 Valve Cover.
    I took the casting flash off with a file. Sanded w/220 grit, and scotch bright. Sprayed it with clear engine enamel. Breather is a modified stainless steel unit. There's a hole drilled through the inlet tube, so the breather won't fall off.
    I used lacquer thinner for the cleaning, including inside the baffle. I used prep sol for the final wipe, prior to clear coating.
    '92 Geo Metro XFi
    '87 Suzuki Samurai
    '85 F150, modded 300cid
    Looks good
    -Greg
    Redneck Engineer
    FOTY - '09
      nicce work... i know its a pita to polish a v/c. i gave up and painted my kia one
        It turn out sort of 'pewter' looking, rather than brite aluminum. The clear coat should keep it this way.
        '92 Geo Metro XFi
        '87 Suzuki Samurai
