B6t fuel injectors on a bp
  • B6t fuel injectors on a bp
    Hey guys I got some b6t injectors off of chris and I stupidly assumed they would just pop into the bp harness but they don't do I need to get a b6t injector harness? Our is there something else I need to do to get them on. Sorry I know this may be a dumb question.
    Your BP has the round plugs?? I have an early B6 injector wiring harness that I could cut the connectors off for you to splice in to get those injectors working
      You will need connectors for the B6T injectors. I have a set w/ pigtails ready to go if you need em. $25 shipped
      1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
      Rocketchips!
      Bolt-on Weber Carb Adapters!
        He already has the injectors, just needs the pigtails
          Yea. It sucks but thanks for your help. Your stuff should be on its way bro. I took it all apart today and realized I need a full injector gasket kit because the weird o-ring at the base of the injectors are bad and 1 was completely shot.
          25 sound good a long as thats what I need. You got a gasket kit layin around as well?
            Plugs is what I meant, not injectors sorry. heres what I got
            No gasket kits though
            Rocketchips!
