Originally posted by zoe60
By drddan at 2012-05-29
Screw puttin' it in a lathe. Too much work!
I will be using a mech. pump.
Took my air grinder and 1 inch fine sand drum, and polished it. Done in 15 minutes. The shape is there, it was just the cast surface needed removed.
After measuring around on it, the "eccentric" wasnt as big as on the B3 cam.
Turning on a lathe and 4 jaw chuck (good call Movin'!) was judged a waste of time. The B6 cam didnt have as much offset, on the eccentric, and would have wound up a slight bit smaller diameter, and therefore, less lift on the fuel pump arm.
Prolly not enough to notice, but decided on the polish job.
Left some of the "witness" marks from the casting, on the eccentric to hold oil.
