How much should I pay for porting and polishing my BP head?
BP porting and polishing
Lots lol for a proper port/polish job, it's very time consuming
PnP gets expensive fast.
Depending on the shop and the experience of the porter.
It can be as low as a few hundrend dollers to several thoundsand for a full on race cnc port with hand blending.
There are other ways to help the air flow thu the head that you may want to considered.
Installing oversized valves is one, having a better than stock valve job is another.
To me a 3 angle is "Basic" and still stock.
Now OP, what is your goals and end use for car?
Now from what I have seen of the Mazda BP head, the casting is extreamly rough and can use a basic casting flash clean up.
ohhhh If you want the straight up sex in porting.... Check this!!
Sadly all they list is for the honduh
FlyinMiata does port work on BP heads, or can sell you a pre-ported head, but it's $$$$1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
