Anyone ever installed an aftermarket radiator from another car into a Festiva? I want to move up to a nice aluminium 3 core radiator.
Aftermarket Radiator
Yes the ATX Aspire units are money.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
^ the civic rads fit good
you gotta weld the bottom outlet shut and move it to the side, if you look close you can see the patch welded over where the factory civic outlet is...
Mike, AKA the sasquatch
So your sayin a del sol radiator can work with no cuttin of the rad??Frankie
fully custom 88 festy (project doomsday) Febuary in 2012 calander
Blockspire: ken block replica aspire
AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
http://www.facebook.com/#!/profile.p...00000110128487
I'm actually using the same civic radiator in original (2 core aluminum) configuration. I had to relocate the mounting points on top on my custom box tube lower core support, and 2-piece the lower hose. It was a little tricky, but its working great.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
I like my stock rad...bolts right up...hoses line up too...-Greg
Redneck Engineer
FOTY - '09
I have a VW rad
