Is there a V pulley(outer) that will fit on a 89 B6. The original one is a serpentine. I have A/C in a 93 Festiva with a V pulley and would like to hook up the A/C. I tried swapping the V pulley from the festiva motor but the crank keys are different and the pulley is too short to fit within the balancer. Please help!!!
crank pulleys???
Your '89 engine probably has the "small nose" crankshaft and your '93 has the "big nose". You will have to find a pulley from an older model Festiva that had air conditioning to fit you '89 engine. Any year before '93 should work.You gonna race that thing?
ThanksOriginally posted by Festy46Your '89 engine probably has the "small nose" crankshaft and your '93 has the "big nose". You will have to find a pulley from an older model Festiva that had air conditioning to fit you '89 engine. Any year before '93 should work.
 didn't remember the 93 pulley was the same as the aspire..
