We need to come up with a crank pulley for our swapped motors other than a 93festiva b3. If someone can make one or has found another form that would work that would be grrr8. I have 2 motors at home missing pulleys cuz ive used them on swaps already....any ideas.
CRANK PULLEY THREAD
Why is everyone so insistent on V rib belts? I know it's not a clearance issue, and most swappers don't care about a ac compressor or power steering. KIA Rio's have a big nose, aspires have big nose, but their 4 ribbed belts. (serp imo implies it is 1 belt that controls all, which is not the case with 4 rib belts on aspires and kias that have 2, 4 rib belts)2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Early BP's have a small nose, in fact I have one right now that will go onto the B3 once I pull it out, it is a clearance issue on the BP swap, because they all had PS or ACOwner of:
1991 Red Festiva L, 5 speed (Swagger Wagon)
In progress:
BP+G25MR swap, Kia rio axles hopefully.
It's not a clearance issue, clearance is elbow grease and a deadblow/2lb sledge hammer on any bp/g swap. I don't know many people that care to have PS on a festy-or aspire- especially with the rio tops being what they are.Last edited by zoom zoom; 09-18-2012, 09:57 PM.2008 Kia Rio- new beater
Mine is an escort bp small nose, with the serpentine machined off. I then used a stock b3 AC pulley inside the bp damper.
It works great. period.-Greg
Redneck Engineer
FOTY - '09
random pulleys i had laying around. i have a festiva pulley on my BP, not sure the year of either though lol. in fact, its been so long im not even sure if its a large or small nose crank. i do know i've never had a 93 B3 though...
						1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
those are all small nose
pulley number 1 probably fits inside of pulley number 389 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Here's large nose Capri damper, inner section. It uses a separate outer 4-rib pulley. Small nose is the same way
						1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
My new engine will have a long nose crank. I'm using all the pulleys from an mx3 (z5) and an mx3 alternator. They are the thin rib belt pulleys that take less power to turn than a traditional v belt and also require less tension ( good for the waterpump). These pulleys are not much wider than the v belt pulleys, so clearance isn't a problem. I won't be using the accessory pulley ( no power steering or a/c).Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
anything 93 and newer is long nose. Some 91 and 92 engines are long nose, anything older than 91 is a short nose. This seems to be consistent among all b series mazda engines. Z series 4 cylinders all seem to be long nose ( they are all newer than 1992 anyway).Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Thats the bp i used last. You'll need the other timing cover pieces to make the vc work properly. Also they have a pickup wheel on the front of the crank that would work good with standalone ecus.Originally posted by Ford Fester View PostI will be raiding our yards after madness. Anyone know specs on a 1997 bp? There is one in the yard....what should I grab? I took valve cover already.
They are big nose, but have a serpentine pulley IIRC-Greg
Redneck Engineer
FOTY - '09
