Doing a BP swap with a G5M-R transmission, I wanted a simple system for the clutch cable. Preferably no hydraulic installs, no door hinges, or pivots to clutch masters to slaves. I ended up taking a long time to find the solution but I think it was worth it. I hope it proves to last well because it's infinitely adjustable and an easy fix if anything goes awry!
--The Install--
So the first thing I did was find a beefy throttle cable at the wreckers that was longer than the Festiva clutch cable. I thought I could make it work, so I built a bracket, tested it but found that the cable stretched too much and slipped out of its retainers. Turns out throttle cables are not nearly tough enough for the job. Not surprised, but I wanted to try.
Plan B: Look for a longer clutch cable in all the cars at the wreckers. The cable must be similar to the Festiva's at either end and have just the right amount of action, adjustability and minimal distance between bracket point and end-of-rope point (I just made those terms up...)
So the clutch cable comes from an '84 Volvo 240, obviously with a manual transmission. The wonderful thing about this cable is that it uses a metal flexible sleave, much like those on some old desk lamps. This makes it stronger and less prone to deflection when stressed. Additionally the cable-tension adjuster works by winding itself up and down this flex-sleave! This means you could technically adjust it along the ENTIRE length of the ENTIRE clutch cable. Love it.
So I first found a point on the transmission to mount the bracket that would provide a little bit of aluminum meat to support the torsion from the bracket when your pushing in your clutch. This spot was ok:
But it meant that I had to do some extra work on the braket mounting point to clear that tab (yeah I could have cut off the tab, but I don't like to). Here's what the bracket looks like:
The cable itself has a nice big ball on the transmission end, so you just cut a little slit into the clutch lever and slide it in and the ball will naturally recess itself in the pre-existing divot:
Here's the same shot pulled back a little:
The interior end of the cable resembles the Festiva one, except that it has a removable pin. It's easy to install and sits like the stock one. The plastic retaining tab on the cable also fits nicely into the bracket on the clutch pedal frame (ignore the crazy greasy dust, it hasn't been cleaned yet!):
Here's a closeup of the end:
This is a closeup of the adjustment ring on the cable. The ring rotates and slides itself up and down the ridges on the cable sleave - ingenious and simple:
All installed and cinched up! A couple tests proved it to work fantastically:
I'll let everyone knows how it goes after the rest of the car goes together and its had a couple slow rush-hour drives.
					--The Install--
