Hey All:
I was reading on another forum that the 626 transmission is marginally stronger then the g series, The bell housing should be the same as the festiva correct me if im wrong
Here is the thing: I found a super cheap FE3 out of a Sportage on kijiji.... There has to be another stronger transmission readly available that can bolt into a festiva.
We need a trans sticky thread...
you will have to get custom axles made or swap in the 323 gt diff to get the right spline count to use 323gt axles or maybe you can make the 626 or escort gt axles work...
