Hey guy's, I was wondering if it would be possible to swap the distributor and coil from a EFI Festiva to a EFI Aspire (Aspire has electronic ignition I guess). What would I need to do the swap, and is it even worth swapping it?
ignition setup
the aspire has an internal coil akin to Hondas. as of this point there is no conversion for them and therefore no upgrades that i'm aware of. i DO recomend you hop on over to FAST and ask those guys, they may have a different answer.Trees aren't kind to me...
Ok, oh well, only reason im asking is out of curiosity, and i got a tune up kit, and the wire set came with the 5 plugs, 4 for the plugs n one for the coil. Would it be fine if i just use the 4 for the plugs n not use the one for the coil since i dont have one
