It's clear that there are fans of water injection on this forum & that's great & I will the 1st to admit, dyno results don't lie. It definitely works! But my only point is at what cost & is it worth the fee? Owning & operating a professional engine shop allows me to see the other side of the coin. When engines come in for freshening up or tear down from a potential problem, I get to see things that most wouldn't get the opportunity to see. After building over 1,500 engines the opportunity to notice a pattern. 2 such examples...1st is a 4.6L Modular with a 72 mm turbo. This engine cost the customer $14,300 & produced 686 HP at the wheel. At some time later, the customer installed a Snow Performance Meth Injection System, which increased the HP to 744 at the wheel. A welcomed increase indeed. After only a few months after the install of the meth injection kit, he noticed a distinct reduction in power. A leak down test showed an extensive amount of cylinder leakage in every cylinder. The following pictures are of the damage. The bad thing about this particular engine is the cylinder heads are ultra rare limited production Ford SVO Racing Heads, only produced between '96 & '98. These pictures may not show it clearly, but the steam pitting on the valves, which are high dollar Del West valves, is pretty bad. The reason for the leak down was pitting in the cylinder walls due to the steam. It also ruined the Moly facing on the rings. The 2nd example is a '00 Mustang. We installed a Paxton Novi 2,000 Super Charger on, the engine was completely stock & produced 432 HP at the wheel. In the same fashion, this customer installed an Anderson Motorsports water meth kit. Later in the year, he brought the car in with ticking noises. Tear down revealed excessive moisture in the crank case. It caused the oil to foam in the hydraulic timing chain tensioners, with the loss of pressure, the tensioners collapsed, allowing slop in the chains. This allowed the pistons to smack the valves. I found extensive rust abound with in the crank case. The water had also caused the one rist pin to seize. Not the intent to enrage anyone, as this often causes the point to be lost, but this is the facts. Sometimes my job is to inform people that what they have thought all along or "read" has more to the story. These 2 customers above, I assure you, realized that I wasn't calling them stupid when I discouraged these installs, but looking out for their investments.
