Bad head gasket on my B6.  Hopefully my engine is not damaged.  There is coolant in cylinders 3 and 4, with cylinders 1 and 2 dry and normal.  My "help" thread is here, with pic of spark plugs on page three:
I have two backup cars that run and will get me to work. They should both last at least a week. I hope!
I'm thinking a valve job, some head work, and maybe shaving the head for a bit more compression. When I rebuilt AquaMutt about 1.5 years ago, I took the head off (from the B6 my Dad and I had pulled from a 'yard a few years prior), the engine to check it and took it to a shop to have it cleaned, checked and decked. Nothing else was done.
This time I'm thinking a valve job, mild port and polish and maybe some shaved off the bottom for a bit more compression.
I'd be looking for about a ten percent gain in hp. Maybe 6 to 12 hp is all. FYI, my B6 is fed from a CAI and fumes spit out through a stock exhaust manifold with the entire exhaust being a 2" piped system with Magnaflow low restriction cat and standard low restriction muffler. No other power mods. Stock B6 TB.
May as well turn this little setback into a bit more performance, eh?
Comments? Ideas?
One more thing: that was my first time working on an engine (besides new seals on a B6 for Luxstiva the first time, but I didn't take that engine apart at all except for both manifolds). On this one, I took off the head, oil pan and MBSP, installed new gaskets, seals, and of course my head gasket job must not have been too good.
I'm wondering what else I should be thinking now. I also used that copper spray on my new head gasket. Can't recall what brand the gasket was.
Karl
Comments? Ideas?
Karl
