I've studied the various solutions members have found to adapt a Escort Holley/Weber carb to the 1.3 manifold. Seems the 3 schools of thought are:
- Weld the manifold and tap for a new stud pattern
- Build an aluminum adapter to accommodate both stud patterns and transition the pattern from escort to festiva
- Build a steel adapter that brings the escort pattern to a festiva-like shape to fasten on the manifold
I'm considering a slightly different approach to the second option that would be simple enough for anyone to build.
As I have the gaskets lined up, it would seem the only obstruction is that "lip" where the circle is flat. My thoughts are, if I grind this portion off the manifold, could the adapter I construct be of the escort pattern with 2 holes?
Here's a photoshop to give you an idea of what I'm considering. Is there any room to shave this back a little?
