Hi 'ya folks,
Here are some pictures and schematics on my recent B3 MegaSquirt install.
I built an adapter to mate the Megasquirt DB37 to a Festiva harness.
The adapter was made by cutting off the main connector (header) off of a Miata ECU and wiring it to the DB37. The Festiva and the Miata use the same ECU connector and Miata ones are a dime a dozen.
ECU DB37 DESCRIPTION
B........28........Main relay, hot in run
G........36........To ignitor
N........22........TPS signal
2A......8..........ground
2B......9..........ground
2C......10,11....ground
2D......19........signal return from TPS
2E......24........ignition signal from distributor (jump to pin 26 with 1K resistor for ign pullup)
2L......26........5V reference for TPS. (also jump to pin 24 with 1K resistor for ign pullup)
2N......23........O2 sensor. Use a wideband for infinite tuning.
2P.......20.......Manifold air temp (MAT)
2Q......21.......engine coolant temperature (ECT)
2U......32-33...injector 1&3
2V......34-35...injector 2&4
2W*.....30*........PWM Idle solenoid. DO NOT CONNECT without modifying Megasquirt first. You will destroy the ECU.
Actually the PWM idle solenoid is not required and the B3 will idle fine without it. You have to manually adjust the idle screw on the throttlebody for idle. Cold idle is handled by the coolant flowing through the idle valve.
pin 30 on the DB37 goes to the fuel pump relay.
In my instillation I eliminated the mass air meter and used the MAP sensor built into the megasquirt. Eliminating the mass air meter also eliminates the manifold air temp sensor (MAT)... so you will need to supply a new MAT sensor.
This is the adapter
It is recommended that you also use a wideband O2 controller. A narrowband will work but it is pointless to use a narrowband with Megasquirt. I used a LC-1 from Innovative Motor Sports.
Unfortunately I don't own a Festiva. This install was on a Miata that was electrically modified to be identical to a Festiva. I have no idea how the megasquirt will perform on a Festiva, but it works great on my B3 powered Miata.
Jim
This is the adapter
Jim
