the FMS units were both tri-y headers. i have the B6 unit as well and can't say that i like it all that much.
Dickmeyer Automotive Engineering Race Header B3/B6
Originally posted by FestYboy View Postthe FMS units were both tri-y headers. i have the B6 unit as well and can't say that i like it all that much.
Matt, I don't know how many dyno runs you did, or in what state of mods, but could you provide some details on the results of the testing concerning the tube header? I realize you may not have even wasted your time dyno'ing the stock manifold, but some idea of the potential gains through the rpm range with stock and ported head would be sweet and may even help with the sale.Brian
Originally posted by mattdickmeyer View Post$300 & it includes 2 bungs as shown.Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
Originally posted by blkfordsedan View PostMatt, I don't know how many dyno runs you did, or in what state of mods, but could you provide some details on the results of the testing concerning the tube header? I realize you may not have even wasted your time dyno'ing the stock manifold, but some idea of the potential gains through the rpm range with stock and ported head would be sweet and may even help with the sale.PROPOGATE! AND FACILITATE!
Originally posted by mattdickmeyer View PostTo be honest, I tested that over 3 years ago & didn't keep the file. As I recall header was worth around 8 HP on a stock Festiva & around 14.5 HP with head work. I will be doing some testing on some parts that I am developing at the present & bought a stock '91 Festiva to test with. So I will be able to start from scratch with base line numbers all the way to highly modified.
^X2 can't wait to see some dataBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
Originally posted by mattdickmeyer View PostTo be honest, I tested that over 3 years ago & didn't keep the file. As I recall header was worth around 8 HP on a stock Festiva & around 14.5 HP with head work. I will be doing some testing on some parts that I am developing at the present & bought a stock '91 Festiva to test with. So I will be able to start from scratch with base line numbers all the way to highly modified.Brian
Gidday mattdickmeyer! This business of yours with seeking to improve B3s is quite intriguing. The roller rocker arm cylinder heads of Aspires are supposed to be better performing. Wikapedia: " Mazda B-series engines" says carbed B3s were rated at 58 hp, EFIs 63 and that later B3 models were good for 70+ hp. Is it possible that Aspire B3s are that much more powerful and have you ever looked inside one? The manifolds and injectors are larger and the exhaust manifold is tube steel instead of a casting.
My very limited understanding of headers is that 'tuned' versions have functionally-equal length pipes going into a collector and that taking into account bends and/or curves in order to do that is a real art.
I'm following these posts with great interest.
Bert, all North American EFI B3s are 63 hp, and the Aspire exhaust manifold is horrible for scavenging, so they were stealing from Peter to pay Paul by running the roller rockers...Trees aren't kind to me...
Originally posted by FestYboy View PostBert, all North American EFI B3s are 63 hp, and the Aspire exhaust manifold is horrible for scavenging, so they were stealing from Peter to pay Paul by running the roller rockers...
^DOHC b3 hmmmmmm that would be awesomeBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
the festiva GT-A had the DOHC B3 (Japan only) and made ~88hp. Bert the 73hp B3 that you refer to is installed in eastern market 323s (BF/G only) and Laser, they mistakenly pulled the info from the Mazda B series engine article without verifying which cars it was installed in. the higher HP engine was destined for the larger cars (323 and Laser) where the Aspire and Avella kept the 63hp version. they also state the the 72hp engine is a 16v sohc. i've seen one of these heads and they are WIERD and i can't say that they'd swap over without all the fixin's to go with them.
that and the FSM also states 63hp...Last edited by FestYboy; 01-04-2013, 11:39 AM.Trees aren't kind to me...
