So I've found a five speed at the junkyard, and after helpful insight from FestYboy, I know there are a couple things I need to make sure to grab that I hadn't intended to get.... one other thing I was wondering, comparing the Part Numbers on AutoZone.com it appears that the manual axles are the same from basically 88-94... reason I specifiy those years are because mine is an 89, the JY car with the 5spd is a 93, and the JY car that has good axles (if I remember correctly) is an 88.
Now the thing I'm wondering (because AutoZone doesn't specifiy) is that are the manual axles the same whether it's a 5 or 4 speed? Because the 93 car with the 5spd is... well... a 5spd. But the 88 is a 4 spd. I'm just looking at trying to save a couple bucks by grabbing some axles that look like they're in pretty good shape versus axles whose boots are thrashed apart...
If no, or y'all don't think I should even attempt, then I'll just buy new ones for the $45-50/axle
Thanks in advance
Thanks in advance
