I need some help with some insight.  As I understand it the B6D is a SOHC 1.6 16 valve engine, but the questions I have are as follows:
1. Is the SOHC 16v engine much better than the SOHC 8v engine
2. If so, will my carbed intake bolt up to the head
What I am looking to do is get the best direct fit 1.6 that I can still run my carburetor on. I plan to do quite a bit of massaging to the engine (by way of Dickmeyer Engineering) but I want to start with a bit higher displacement while at the same time not having to do a lot of custom fabing to get it to fit. I don't want to convert to FI because it is too much of a headache and tuning a carb is more user friendly. Here are my end goals for the festi: a 1.6l with Dickmeyer ported head, Dickmeyer Header, Custom intake manifold (yet to be designed but researching), Weber 32/36 carb, Dickmeyer custom grind cam, 2" exhaust. I want something real streetable, that still gets pretty good fuel mileage, but will still pull away from the hondumbs. Any help would be greatly appreciated. Thanks, Robert
