Dickmeyer Automotive Engineering Festiva/Aspire Bolt-On Adjustable FPR Kit
Looks like a B6 fuel rail??? What is included, and will you take a bad check from out-of-state? (Never hurts to ask)
I saw the pics on Facebook...looks like a high quality unit.Brian
i like it, now what's the bottom line?Trees aren't kind to me...
yeah it is.... the next question is can that unit act like an FMU?Trees aren't kind to me...
Originally posted by FestYboy View Postyeah it is.... the next question is can that unit act like an FMU?
Nice. Xwhatever to the FMU question. It looks to be not proportioned like other FMUs with room for a big disc in it, but I'm thoroughly speculating. I wouldn't expect full adjustability from a $100 FPR, but then I never expected 266hp from a B3 either.
More knowledge, please.Any difference that makes no difference is no difference.
Taken straight from the description of one of the pics on Matt's Facebook.
Each FPR is 100% hand built here at DAE. Offering exceptional quality that I guarantee because I built it. Out FPR's are available in 2-port & 4-port configurations for Carb & EFI applications & are threaded for AN fittings or NPT threads for simplified, cost affected applications. All EFI applications feature 1-1 boost reference & are available with or without pressure gauge & are completely rebuild-able. Also, '86-'98 5.0, 5.8, 4.6 & 5.4 direct fit applications are available with more to come. Effective immediately, ALL FPR come standard with GFLT pressure diaphragms for use with leaded/unleaded gas, blended fuels & ethanol/methanol.
For reference it is the last picture http://www.facebook.com/media/set/?s...6867515&type=1 in this album.Last edited by gergorian; 03-06-2013, 02:40 AM.
So 1:1. Still a great deal.Any difference that makes no difference is no difference.
Our Pro-Series Billet FPR is a regulator not an FMU. It does have 1-1 boost reference. If turbo charged with OE ECU & injectors, an FMU is used in conjunction with the FPR. The biggest advantage with our unit is the adjust-ability of 20-80 PSI rail pressure, which is necessary as performance is increased on an engine. As ported intakes & heads, cams & headers & just plain anything that increases power, the engine will run lean offering less performance from your mods. Since most of you don't want to spend the money on a DFI system, fuel pressure adjustment is the only way to manipulate a fuel enrichment system. I have dynoed these engines & found significant changes in performance just by adjusting 2-4 PSI of rail pressure. The biggest advantage is when CI is increased such as a B6 swap running B3 ECU & injectors.PROPOGATE! AND FACILITATE!
Is there an application for this for non-turbo cars? Say, a 100hp B6 or an 80hp B3?
Absolutely perfect for this application. Dialed in AFR & significantly increased drivability & mid-range torque. When our test Festiva was @ 70 RWHP. Since then it's 112 RWHP & is an absolute must at this level. With OE ECU & stock injectors, 62 PSI rail pressure is needed to correct AFR.PROPOGATE! AND FACILITATE!
So, just to make sure I understand, does it use a vacuum signal like the OEM regulator as well?Brian
