Manifold "swap"
  • Manifold "swap"
    First sry if this is the wrong pkace to post, seeme
    d apropriate. Is there any pros or cons to putting an aspire manifold on a festy?
    ReD 91 L FIRSTiva
    92 silver 5spd with some boost! Kratos
    No. But the tubular steel design of the Aspire exhaust manifold makes a good start for a custom turbo manifold.
      OutHmmm is there a thread for this?
      ReD 91 L FIRSTiva
        What ?
        New build on the way .
          Apparently the Aspire tube steel manifold is longer than a Festiva cast item. This would mean that a standard Festy downpipe will have to be modified to fit. May well be that an Aspire version of that same downpipe can be adapted to a Festy system though. Posts on this forum don't seem to favour the Aspire exhaust manifold, except for easy modification for the purpose of installing a turbocharger.
            Aspire mani fits if you use down pipe also ! Power increase none !
