Hi everyone - I have a new (to me) 93 Festiva with a BP + G5MR swap. I have been driving it for a bit to figure out any quirks the car has. The biggest one so far is the engine/tranny mounts.
I had an odd clunking noise start in the car that helped let me know that both tranny mounts had let go. Thank god for the subframe support!
So, my question is does anyone recognize the altered mount being used in this picture? The second one is showing the "welding" that was done to hold it all together. I have a bad feeling someone spot welded it to mock it up and forgot to finish it. I need to know what the piece with the rubber mount is from as it has almost separated completely and I need to find a new piece.
Here is a photo of the front mount. You can see where a piece has been (spot) welded to the top. And yes, it was held together with one bolt. I have since made a new piece up that uses both holes (Luckily the bottom hole wasn't damaged all the way through.) but I can see the bottom rubber is split and the angles don't look very stress friendly at all to me. Again, does anyone recognize the bottom rubber piece?
Now, that being said, should I consider going a different route for the mounts? I see some mention of modified mounts from an 02 Kio Rio? being used for the rear transmission mount. (near firewall) Is there some killer combo being used out there I should be doing?
Thanks for your time and any help you can give!
-Tom
-Tom
. Just cut the lower part & weld plates which bolt to the round piece.
