hey all, I've decided to start out with a NA build on TruckStiva then go back and turbo it. My question is this, using a bp ecu, and vaf. will it start and run okay with factory bpt engine, injectors (360cc), and fuel press reg? also when I installed my fuel cell I had to go over to a inline fuel pump and am curious as to if the one I've found will operate with the correct pressures and gph. Ill still be turboing it I just want to get the kinks worked out first .any info is appreciated thanks -Dan
fuel pump information
Inlet Size: Inlet-5/6
Item Grade: OEM Standard
Maximum Free Flow Rate (gph): 40
Maximum Pressure Range (psi): 95
Minimum Free Flow Rate (gph): 30
Minimum Pressure Range (psi): 70
