Ok so i was doing some research on gear ratios because i know alot of us run larger tire sizes on our cars now adays. What i dont like about my 185/60/r14 is that my gears seem really long now, and 5th gear is almost somewhat useless. So i was reading about what some of the other threads on here were saying about the festiva vs aspire mtx 5 speed and it seems there was some misinformation. All of the gear ratios of 1-5 are not the same.... now stay with me here.. 1st 2nd and 3rd are identical, but 4th and 5th are not. here are a couple links on the stock specs of the two transmissions.
1994 ford aspire 2 door mtx 5 speed
1988 ford festiva lx mtx 5 speed
Now i got the stock tire size and entered it into the garage buddy app on android (if you dont have this it is a great app with tons of calculators for mechanical work) and wrote down the tire diameter size= 21.1 or 21.44 for 13 inch rims now i am running the 14 rims with 185/60 which tire diameter comes out to 22.74 thats why my gears are so long now is from the larger tire diameter. Now i went to the garage buddy tire size gear calculator and entered my original tire diameter of 21.1 and the new diameter of 22.74 and (referring back to the links i posted it gives you final drive or differential gear ratio) the festiva diff ratio of 3.77 and it spits out the proper gear ratio for the larger tire diameter, which= 4.06 now once again refer back to the aspire link and see the final ratio of the aspire mtx= 4.058 Wow thats almost perfect to put me back at stock ratio, so my speedo would be almost exact and have shorter gears which = more power and will still be great on the highway.
Now if you look closer at the 1-5 ratios you will see the aspire is a little taller on 4 and 5 so yes you will see a slightly higher rpm on the highway but will be minimal.
