what other vehicle headers will fit on the BP ?
BP EGT Header question
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
Tags: None
Protege, and I am sure there are moreBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
i mean not the basics you would think like out the box like 99 protege .;
'92 Festiva L M/T
'93 Festiva GL A/T
Kia Sephia's they had BP'sBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
the 1995 ford escort GT came factory with a nice looking tubular manifold on it... if you can find one in the junkyard that may be a lot cheaper than buying a nice header...
Mike, AKA the sasquatch
I have header and manifold I just need the front pipe for a header.;
'92 Festiva L M/T
'93 Festiva GL A/T
'92 Festiva L M/T
'93 Festiva GL A/T
I bought this one it is good quality, IT IS VERY IMPORTANT THAT IF ANYONE GETS THIS YOU HAVE TO BUY THE BOSAL EXHAUST FLANGE GASKET PART NUMBER 256-650. I tryed every gasket (duralast, felpro, walker) from autoparts stores and ended up ordering the bosal one and it was the only one that fit the three holes on the header.
BOSAL 751-115 Exhaust Pipe
BOSAL 256-650 Exhaust Pipe Connector Gasket
1991 stiva.
