I installed a b6 SOHC 8 valve engine into my 1995 Aspire. I have just installed a 5 speed from a 1989 Tracer in the car as well and took out the automatic transmission, In the process I decided to replace the manual steering rack with a power unit. So I went to the salvage hard and got all of the brackets and a power steering pump from a 1995 Aspire that had power steering and air-conditioning in it. After everything was bolted into place and all of the fabrication of mounts etc was completed we discovered that he serpentine belt pulley from the B3 engine in the donor car would not fit the crank on the B6.
Has anyone run into this problem and if so how did you solve it??
cortezit.
cortezit.
