Alright
Finally got my disaster together. Thank the previous engine for putting a flame under my ass. She burned another valve the other day. And it's my daily driver.
1.3, factory ecm,
Polished the stock head.
Milled 0.048" off head
Clevite pistons. Jumped from factory 5cc to 3cc
And she's 0.02" over.
Had to jump a tooth on the cam gear, factory line up would spit past intake valves... So, quick fix was to clock cam one tooth. Not sure if it was too much, or not enough, regardless if either, will need an adjustable gear. Anyways, it runs. And damn good too, even if it's not perfect. I'll vacuum gauge it later this week.
It's odb1, so I can't realtime scan with my scanner to grab temp readings. I'm breaking it in without the thermostat.
Had a partial tank of 87, and topped with 92. When temp gauge starts to creep into mid warm, with factory 10* advanced she starts to chatter at lower rpm, ie gagging engine with clutch to roll ahead. Given, lugging higher CR engines it'll happen, but hotter it gets, worse it gets, and it's a lot when radiator needs fan assistance. Also would like to look into changing when the fan kicks on. Like to see the fan keep the radiator around 150/160.
I was going to experiment with a lower temp thermostat first. Question is, I have no time or knowledge hunting odd parts for this scenario, and wondering if ppl could help out. Or sticky this thread for anyone wanting to follow, or exceed what I've done/doing. I'll help out with what I've ran into, and what was needed to get around. But need to make sure the fan stays within reason with the thermostat, especially when sitting in parking lot, or heavy stop/go traffic.
If I can get this under control, and stay on pump gas, wondering if I could of gone further? Mhahah, 2 more heads sitting under bench...
I guess I'll just post this and see what questions arrive?
Thanks ahead of time.
Sent from my rooted HTC Supersonic using Tapatalk 2 Pro
1.3, factory ecm,
