Gotcha.
DAE Max MPG CAMSHAFT
Oh, no sorry about that. The normal one will be fine.Any difference that makes no difference is no difference.
I will be finishing your mpg cam shortly, aswell.Last edited by mattdickmeyer; 08-22-2013, 10:00 AM.PROPOGATE! AND FACILITATE!
Sweet. Can't wait.
Oh, goody!Originally posted by mattdickmeyer View PostFirst round of MPG cams are finished & will be shipped to all who ordered!
I have mine, but gotta wait for a rocker swap and then a baseline for the now colder weather. Then it'll probably get colder right after I do that.
Couldn't wait. Cam is in along with solid lifter rockers. No other changes. Didn't adjust timing(valve or ignition), didn't change fuel octane, no adjustable FPR. Cam in, adjust valve lash, done.
Previous average MPG is 43. I'll post back with results in a week or 2.Any difference that makes no difference is no difference.
So this is a carby? Since you mentioned adjusting valve lash.Originally posted by sketchman View PostCouldn't wait. Cam is in along with solid lifter rockers. No other changes. Didn't adjust timing(valve or ignition), didn't change fuel octane, no adjustable FPR. Cam in, adjust valve lash, done.
Looking forward to your results. How about starting a separate thread for this, in case you decide to change ignition timing, carb parameters, etc.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Nope. EFI but with the old style solid lifter rockers.
Will do the thread now.Any difference that makes no difference is no difference.
POOP!!! How did I miss this?!? What do I need to do to get on the cam bandwagon? I've got an auto and a 5-spd I'd like to stick a cam into each. The auto doesn't typically see any speeds over 45-50mph. The 5-spd is usually 55-60mph max.1963 Fairlane - future NSS drag car
