I will be doing Aspire roller rockers with a beefier cam very soon. I just swapped to the solid lifters on my stock cam, and I like what they do. Low idle is steadier and the bottom end feels(I don't know how else to put it) snappier, more solid on/off throttle. If that makes sense.
So, what I'm looking at doing is yanking the hyds from the roller rockers and drilling the arms straight through the top to thread and use a set screw with a jam nut on top just like the old school solid Festiva lifters are.
Anybody done this, and what material did you use? I'm thinking a stainless set screw would hold up, and they come pretty cheap. Do I need stainless? Would a normal set screw hold up?
Pretty sure I remember mattdickmeyer showed some that he used to test things, but I don't think they were meant to be used as a lifter.
Thoughts?
Thoughts?
