Aftermarket Fuel pump BP
  • Aftermarket Fuel pump BP
    Is anyone running a aeromotive fuel pump?
    Why spend that kind of money when a Walbro 255 would most likely be more than you would need and alot cheaper.
      Just heard walbro wasnt that good? I must be wrong thanks
        Never had an issue with wallbro ! I've owned six or seven !
        New build on the way .
          Sick right on guess im going with the walbro! thanks, I just got my turbo and it looks like its going to hit the radiator. Is it alright if I clock the turbo? the turbo piping looks like it would go right through the radiator
            are you going with a intank pump? I hear the Walbros can be noisy and there are better options out there for intank use. Check http://www.deatschwerks.com/ lots of miata guys use them with good success. When it comes to building a b6t/bpt its best to follow the miata guys, they have tried every part and they know what works and what doesn't. Im sure a Walbro will be fine but if you want to spend a little there is more options. I personally went with a Fuelab inline pump which is E85 compatible. My tank is sumped which is probably over kill but i will know fuel wont be a problem for me.
              Right on thanks for the advice! My friend told me he was having problems with his walbro and I just wanted to make sure, hes now running a aeromotive and said it work good. Is there a forum for miata builders? Im going big with my festiva so I just want parts that will be reliable, thanks again
