Well, I spent my last $400 on a TDi Passat [B4 - 1996] with 299860 miles on it, and started working full time again, as well as planning and excavating to build a house hopefully this summer coming, so the Festiva is sitting around on hold for now.
I've been doing some thinking here, and in the interest of ease and using the proper parts to do a swap /the right way/, I'm going to bolt the original transmission back onto the IDI and drop it all under the hood that way, but use some custom-built axles for the swap instead of mucking about with adapter plates and custom flywheels. The shift assembly on the OE transmission is gonna get changed out to the O2J cable-type shifter from MK4 Jetta and similar vehicles, so Ill just have to mount a shifter box in the car, which makes life easier for me because I'll have the ability to alter shifter height, throw, and stiffness/firmness by changing parts around from what's readily available.
For now, I'm going to focus on fixing up the TDi and enjoying it, though. I'll be gathering parts to continue this swap sometime next year [2014] and hope to have it finished [driveable] and inspected by then.
