Originally posted by 1chrisapple
When you change a fuel jet, you are changing the AFR. The fuel and air jets do work in conjunction. Bigger fuel jet= more gas, but in effect, less air with the AFR
and vice versa. When you change to a smaller fuel jet=less fuel, more air with the AFR.
You want to keep the AFR at the correct ratio for the engine requirements. 13:1/14:1 AFR
When a fuel jet is changed, you will want to change the air in the same direction to keep the AFR in spec.
This is how the carb can be adjusted for economy or for performance.
