It's been a while since I drove the beast.
So I decided to take it for a drive today.
Let the car warm up
I turned the adjustable fuel pressure regulator back down to stock pressure.
And set the ignition timing a few degrees forward.
Then I went and drove around the city and on the freeway and whatnot.
So the stock upstream o2 sensor that I extended when I got the DAE header put on.
Turns out to be working fine with the ghetto extension.
I programmed a custom o2 sensor gauge into the scanguage that displays o2 voltage from .01v-.99v
Also had the loop status gauge on for reference.
But what I figured out was that at idle/part throttle and low rpm driving.
The voltage drops down to .05-.07v
And goes into open loop.
Meaning it doesn't stay warm enough to stay in closed loop at idle/part throttle/low rpms.
But if I give it wot or stay in a higher rpm it brings the voltages back into the .30v-.80v range
which is what it should be reading as usual.
And it puts it back into closed loop while there.
So I'm contemplating rigging up a heated o2 sensor.
That way it is better able to stay in closed loop at idle and part throttle.
Bad news is I have a brand new Denso upstream o2 sensor in the box that I've been saving that will be useless to me if I go through with the heated o2 sensor idea.
Maybe someone on here would be interested in buying it off me.
Anyways.
If I got the heated sensor.
How would I wire it up?
Just splice a stock connector to the signal wire and plug it into the harness
Then take the power wire and mount it to a source that turns on with the car and off with the car?
Where would be best location to run the power wire to for this?
And how to choose o2 sensor with compatible thread size and the heating element?
I only payed $34 for the brand new OEM Denso replacement I bought.
And I'd like to have a Denso heated sensor for a similar price if possible.
Any ideas/help would be appreciated.
And another thing.
it was a hot day outside today 80-90
and even still the sensor was cold enough to drop into open loop at idle and part throttle/low rpms.
So I can't imagine what would happen when winter rolls around if I don't upgrade.
when the car is in closed loop or wot this header definitely adds power all around.
I'm really loving it.
Once this heated sensor idea is done everything should work perfectly.
Plus I'm sure this will help others.
Let the car warm up
Anyways.
And another thing.
