i wonder how you solved the problem of the passengers side split driveshaft mount.
i used the bp-dohc and the b6t tranny with the b6t drive-shafts. and my solution looks like this:
i did not finish the car but thought about that mounting thing. is it adequate or will it brake and cause some trouble.
other thing which came to my mind is...if i would have used the hydraulic-clutch tranny from a bp-dohc car could i use the bpdohc driveshafts too? so the split ds mounting would be like in a stock bp-dohc car? or wont the bp-dohc ds fit?
