IAC to Throttle Body Washer Partnumber?
What solvent did you clean it with?'93 Blue 5spd 230K(down for clutch and overall maintanence)
i used Carb Cleaner, but it wasn't directly sprayed on it, all i did was to remove it. I initially removed the throttle body and clean it whole, then i removed the Cold Start from the bottom of the throttle body, to further clean it, i then noticed that particles were logged into the valve. Now during reassembly this washer will not fit into the groove.Originally posted by Pu241 View PostWhat solvent did you clean it with?
JAMAICA TO THE WORLD
I don't complain, i just come plain.
