I was thinking of using a 1.6 DOHC Hyundai Accent engine with an Auto tranny from an 2000-2004 Accent if it works.... thoughts?
Festiva Accent swap
Festiva Accent swap
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
To lift an eyebrow that engine has to beat a protege's economy and/or power by a significant amount, which they do not. Even hyundai cars this decade are barely hitting the 40mpg mark...it is a heavier car so it would do well in a festiva, but those engines arent 185.99 all day long at any yard i know of.1993 GL 5 speed
Ah.... Ya I got an accent andI can go 230.0 -235.0 mile to a full tank and I'm only getting about 25 mpg at it's bestLast edited by old yellow; 09-15-2013, 03:26 AM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Adapting over to OBDII is going to mean entirely stripping out the dash and tangling with a whole other wiring harness. I don't envy you for that inordinate amount of work just so can say you put in another engine. Likely there are also going to be huge obstacles such as speedos (are they electronic in 04s? vs cable in Festys) and other sensors, controls and gauges too.
You are totally wrong there Burt, OBD2 is not much more work then OBD1Originally posted by Bert View PostAdapting over to OBDII is going to mean entirely stripping out the dash and tangling with a whole other wiring harness. I don't envy you for that inordinate amount of work just so can say you put in another engine. Likely there are also going to be huge obstacles such as speedos (are they electronic in 04s? vs cable in Festys) and other sensors, controls and gauges too.
I was thinking of going with a 01 jetta dash also in the swap but I think that would be too much work....Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
might just do an Aspire swap with this engine, as even tho the Aspire is about 200 lbs more heavy then the Festiva, it is still about 500 lbs lighter then the accent and ours hauls butt!Last edited by old yellow; 01-10-2014, 08:26 PM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
