I just got a deal on a 91 1.3 manual trans, just needs a tune up. It has a carb on it and i was wondering if anyone knew of an upgrade jet kit or a different carb that fits. Also trying to find out info about upgrading suspension and different wheels since 12 inch tires are sketchy. Thanks!
1991 Festiva upgrades
Welcome! By you having a carby 91, I'm guessing you must be in Australia or somewhere close. Might want to add your location via the user CP close to the top of the page.
The search is your friend. Plus click on Forum on the left and browse thru the threads. There is a LOT of info in there.
Again Welcome!Last edited by Team Lightning; 09-21-2013, 01:38 PM.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
escort carb
weber carb
http://www.fordfestiva.com/forums/showthread.php?47568-Weber-adapter-plate&highlight=weber+carb+swapDiscuss making performance enhancements to the OEM-spec engine in your Festiva or Aspire.
guy here sells adapter and it just bolts on and very good quality
that's a good start
suspension get aspire front knuckles and tie rod ends. use the stock festy lower control arm. take the rear beam with e-brake cable(its longer on aspires) and get the rubber brake hoses with aspire rear.the one from beam to body hoses. also get rear aspire struts if u r gonna run big wide tires and of course u need the wheels b/c the aspire stuff is 4x100 bolt pattern 13" wheels and the festy isn't.
Seller was wrong its a throttle body not a carb. So far the interior has been redone new carpet '92 seats and been painted black with blue trim. Tune up, a walker sound fx muffler. I need some wheels badly the 12 inchs that are on it are way to small. Thinking of swap for aspire hubs and different wheels.
Get some pics please!Originally posted by Wes View PostSeller was wrong its a throttle body not a carb. So far the interior has been redone new carpet '92 seats and been painted black with blue trim. Tune up, a walker sound fx muffler. I need some wheels badly the 12 inchs that are on it are way to small. Thinking of swap for aspire hubs and different wheels.
Moving up to 13,14 or 15 rims is pretty common, most upgrade to the aspire brakes with the heavier larger rims. I like having 13's with a wider tire, currently I have 14's with a wide tire which is fine but a bit heavy.
14's
Old 13's
Last edited by Charlie1717; 10-23-2013, 03:23 PM.-------------------------------------------------------------------------------------------
My Musica! Click me!
Didn't that car belong to a California forum member a couple of years ago? That stripe on the side looks very familiar.
Sent from somewhere west of here via Tapatalk!Ian
Yep, Charlie bought it from perucho. Clean bp car.Originally posted by fastivaca View PostDidn't that car belong to a California forum member a couple of years ago? That stripe on the side looks very familiar.
Sent from somewhere west of here via Tapatalk!-Greg
Redneck Engineer
FOTY - '09
ya gotta go far for the pretty onesOriginally posted by fastivaca View PostDidn't that car belong to a California forum member a couple of years ago? That stripe on the side looks very familiar.
None of that Indiana rust to deal with. Or all that nasty Florida rust, like on Gregs car.
Last edited by Charlie1717; 10-24-2013, 05:11 PM.-------------------------------------------------------------------------------------------
I'll give you 2 grand for it? I'll fly out tomorrowOriginally posted by perucho View Post
Oh and that thing is sexy!Last edited by Charlie1717; 10-24-2013, 07:40 PM.-------------------------------------------------------------------------------------------
