Does anyone have the info on Denso 195500-2180 injector lag time? Base lag value would be a good start but ideally I am looking for the curve based on the Vbatt.
looking for 195500-2180 lag curve data
rusEfi - DIY ECU
93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway barTags: None
witchhunterperformance.com-Greg
Redneck Engineer
FOTY - '09
I guess you were trying to say that http://www.witchhunter.com can measure that for me for a fee? Because I did not find any data on their website, unless I just did not try hard enough. I was hoping someone just has this data, I guess somehow people are tuning their cars and that's part of setting everything up?Originally posted by eurotiva View Postwitchhunterperformance.comrusEfi - DIY ECU
I would think that lag time depends on many variables.-Greg
Redneck Engineer
FOTY - '09
Maybe I am not getting the right answers because I am not asking the right questionOriginally posted by eurotiva View PostI would think that lag time depends on many variables.
So, in my understanding while an injector (let's assume that all injectors of the same model are the same) has a cc characteristics, there is also the amount of time it takes to open the injector. I was under the impression that these times, which are usually somewhere around a milliseconds, depend on current battery voltage - the lower the voltage, the longer it takes to open the solenoid. Here we assume that the injector has two states - closed and completely open.
What other variables do you see here? I guess we are assuming constant fuel pressure.rusEfi - DIY ECU
