miata vs mx3 piston difference?
  • miata vs mx3 piston difference?
    Can anybody tell me the difference between the 90-93 auto miata b6 vs 94-95 mx3 pistons and will the mx3 pistons work in my b6t.
    ask on miataturbo.net, i bet they may be able to give you the answer. But i do believe i read some where the miatas offered the most compression for th b6
      Well I want 9:1 but I can't seem to find any std. size miata ones and everywhere shows the mx3 pistons are different.
        Calling Zanzer....ring ring
          ^^ You rang LOL :mrgreen:
          I haven't had the opportunity to tear into a 94-95 MX-3 B6D yet so I can't give you specifics, but from looking at some pics it looks like the MX-3 pistons are basically the same as the Miata and Capri B6D pistons. The B6T and B6D use the same cylinder head but I don't know what the combustion chamber looks like on a B6ZE so maybe Charlie can give a little insight here.
          Here's a pic of the Miata B6ZE vs a Capri B6D piston. They both use the same piston.
          Here's a pic of ITM pistons for the MX-3. They look pretty much the same as above.
          And here's a pic of the MX-3 piston I found on the net. The part number on the box says it's for a B6ZE which is Miata.
          WWZD
          Zulu Ministries
            Alright then, the ones I've been seeing on the net look like the last ones you posted and they don't look dished out as much. Now does the mx3 pistons have the cut out for the oil squirter. Guy from parts dinosaur told me the cr is 9.1:1 not 9:1 like I thought.
            Sent from my SAMSUNG-SGH-I337 using Tapatalk
              I would assume that they do have the relief for the squirter since everything from a B6D up has it.
              WWZD
              Zulu Ministries
                Looking on Rockauto, the ITM piston part number for the MX3 is RY6758, while the auto Miata is RY6673. Both say they are 9:1
                  Guy from miataturbo.net says they will work fine, so I'm gonna get some ordered and see how they work out. Thanks guys for your help.
