I still have some cooling issues on the BPT. On hot days 90°+ the temp gauge will stay within the normal operating temp range of 190° to 207°, the thermostat temp and the temp in which the fan comes on. usually no problems except when I'm getting on the throttle or on the highway going 75mph. The fan comes on and stays, the temp gauge will start to creep. I then turn the heater on and it will come down or at least stabilize and stop climbing.
My thought was to fabricate a rear heater box beside the spare tire or in the spare tire well. I'd run hose and/or hard line that I'd tee off from the normal heater hoses. Run these to the rear and into a box that contained a heater core. Install a fan and relay in the box and have it come on at a certain temp. I'd have air drawn from the interior and a hole in the rear floor for it to exit. My first concerns would be getting the air out, might need a bleed off in the rear.
This winter it will be getting some more power so I need to fix the cooling situation 1st.
Thoughts, ideas, comments??
Poverty produces creativity
