Escort lx-e rear ended and for sale for 450$ with 88k on it. Looks like grandmas car but has 1.8 bp dohc. Is this a good deal? How hard is the swap. . . Its n auto trans and i have a 5speed in my GL
bp 1.8dohc swap
It will bolt in and you need to build/fab the passenger (right) side mount. I'm not sure but I think you will need the ECU from an manual Escort for your Festiva since it's a manual trans.
Maybe some one else can verify that.Last edited by Team Lightning; 01-10-2014, 01:17 AM.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
i have an LX-E automatic as my DD. NEVER an engine problem in 2+ years of abuse but the 4EAT trans SUCKS! it just WILL NOT KICK DOWN unless floored and then all hell breaks loose. dangerous on wet roads. this was a real BONEHEAD move by ford. this screamer should've been available ONLY with a 5 spd MT and if you can't shift gears, you had no business getting that engine. i'm sure it was more CAFE bull. but ya, GREAT engine.
U swapped the BP and auto from the protege in your festiva?Originally posted by F3BZ View Posti have an LX-E automatic as my DD. NEVER an engine problem in 2+ years of abuse but the 4EAT trans SUCKS! it just WILL NOT KICK DOWN unless floored and then all hell breaks loose. dangerous on wet roads. this was a real BONEHEAD move by ford. this screamer should've been available ONLY with a 5 spd MT and if you can't shift gears, you had no business getting that engine. i'm sure it was more CAFE bull. but ya, GREAT engine.
I have wanted to do that swap for a while, manly because friends/family couldn't drive my last BP swap festiva, and having that extra gear from the protege auto would be nice over a festiva 3 speed auto. How different is swapping in a bp/auto from a protege? Vs bp/5 speed from protege?
Sent from my SPH-L900 using Tapatalk93L sold. First FESTY!
91L blue monster "BP swapped!" Robbed of its Heart for other Festy!
91GL blue bandit(thanks to sparky) Sold twice! lol
89L (thanks again to sparky) "SCRAPPED without my permission!!!!:nono:
93L Clean Green Machine! (Thanks to Sedat)-Sold to other member!
89 Auto LX Wrecked and stripped. violin
93GL Sold Too Soon!
91GL BP powered, ALL OPTIONS! banana time
If you keep the stock 5 speed the stock clutch will slip like crazy and don't work well after 100hp so I Hurd from several members the exceedy clutch kit from eBay will hold up better I got one and I'm finishing putting mine in my car. But there is 2 extra wires, one on the distributor and one on the brown plug on the passenger side and there is several plugs you got to swap out with the festiva harness. But check out Matt-swabs BP swap guide it's a pdf file has every thang you will need1993 festy "white stallion" BP swap with 7" lift, 1ton wench
R.I.P. 1991 festy "the festiva" stock b3, atv bumper, 8' whip
