Found a Garrett t3 .48 ar. Svo turbo off an 85 Mustang has every thang except the lower oil line andand the down pipee will it work for a BPT? I'll add pics in a sec
will this turbo work?
I'm running that turbo too in the front though.
that down pipe flange is easy to find. I home made a down pipe. It runs good.
Last edited by Flyin4stroke; 01-25-2014, 05:52 PM.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
My tap to talk won't let me log in so I can't get pics right now but the turbo is little more then I want but it won't hurt to get it and save it for another festiva cuz it's only 150$ can't go wrong there1993 festy "white stallion" BP swap with 7" lift, 1ton wench
R.I.P. 1991 festy "the festiva" stock b3, atv bumper, 8' whip
Four bolt down pipe flange? Must be cause it's internally gated.Last edited by Flyin4stroke; 01-25-2014, 07:56 PM.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1996 Ford F-150
Well shows what I know about turbos but got to start somewhere so is the price good and will it last? Mainly needing it for little more hp to help with my 25 mpgs but not to drag race but Yea I'm going to do a lot of research before I build any thang I just wanting to start rounding up partsLast edited by Micro Mudder; 01-25-2014, 09:26 PM.1993 festy "white stallion" BP swap with 7" lift, 1ton wench
Yea I didn't mean better mpg I'll loose a fue with a turbo but I'll have more power to make up for the mods on my car that made my mpg so low. And my 25mpg came from the lift and bigger tires will check actual mpg with my gps speedo cuz mine going 40mph is 92mph I beleave
There is no shaft play
but I'm reading the maximum boost book now so I'll get more egimacated with my learning bout turboing
here's the pics is it worth $150 obo what the guy is asking?
