So I was wacking in my firewall so I could make more room for the bp-t and the seam sealer cracked(the one right above the rack and pinion) cause I guess I hit it to hard! Could this cause problems? how far did you guys wack in your firewall? thanks!
Firewall Clearence HELP
You can buy seam sealer at Napa and other autoparts stores. Apply some new stuff to the crack if it is big enough to worry you.Thricetiva replaced Icetiva as the new ride
Icetiva-3-race-car-build
The only spot that was a problem for me was the center rear of the intake manifold, few wacks with a mini sledge and it fit fine. No need to go all the way to the rack. At least not for my EGT intake manifold. I'll get some pics of my BP-T for you on lunch.Last edited by BUSTIVA; 02-28-2014, 08:45 AM.'93 BP-T 57trim TO4E - Coilovers - 13x7 steelies - 175/60 - 48k mi
