I need a tranny that can handle lots of power. Now, before you all laugh, I know we all want the same thing. I looked into the e153 swap this evening (ALL 31 PAGES) on CP.com won't fit. Short of the unthinkable. I want to keep my car intact.
Is there ANYTHING else remotely close that will fit even if lots of modding is necessary? Something that you have thought about but never had the gumption to try? Something that you may have seen somewhere but never gave it another thought.
G-series just won't cut it. 5th gear plate mod, diff, and looking into straight cut gears but just not quite there I don't think. Can we pool together here and try and come up with anything. I know we are many many years into the FEstiva thing and everything has been tried. But I simply refuse to believe that there isn't anything that can be done.
I'll even get custom axles and adapter plate made if that's what it'll take. Whatever it takes. I like ideas.
Honda, Chevy, Toyota, Kia, Dodge, whatever. If it will fit in between the rails with a b series, it must be entertained.
What about cutting a tranny down. A g series would be smaller if you could eliminate 5th gear right. Is there a larger tranny that we could do something similar to and maybe then widen 2nd 3rd and 4th gears to compensate. No biggie if we have the power to run it right????
